Turnor Brown
I have a NAD 1600 (with remote) that I bought for $100. Unfortunately, I did not test to make sure it had output before I bought it. All of the lights came on, so I assumed it worked.
As of now, the only source of output from this preamp is through the EPL output. There is absolutely no audio coming form the preamp output jack or the headphone jack. The audio coming from the EPL output is very distorted.
I can select any source on the preamp and hear the single audio source I have hooked up to the preamp. Even with the tuner on, I can still hear the audio source. Usually the audio output is least distorted when the proper input is selected. The volume knob can occasionally change the level of distortion heard through the EPL out.
I read that the glue used on components in this preamp can become conductive over time, so I removed as much of it as I could. I also read that the main relay in NAD equipment sometimes goes bad, but mine tested to be functioning normally. I sprayed deoxit in all moving components of the preamp as well. None of these potential solutions have helped my situation.
One other thing I noticed was that even with the preamp switched off, the switched power output on the back of the preamp still had voltage going to it. Turning on the preamp would raise this voltage to equal the line voltage.
I know just enough about electronics to do basic troubleshooting. I'm comfortable with a soldering iron, so working on this preamp should be no big deal. However, I am at a complete loss for solutions at the moment. I watched a video of a repairman working on a preamp with similar issues to mine, however he was successful in fixing his NAD! I'm beginning to become worried that this is a non-repairable issue with the IC's.
I would prefer to fix this preamp myself mainly because there are no repair shops locally. Plus, I enjoy fixing things like this.
Any help would be appreciated.
