I changed all the ‘peeled’ resistors. Anyway……amp works fine, bias and dc-offset is tuned in. When I turned on the (cold) amp this morning, the amp cycled the protect relays 3-4 times before ‘capturing’. Is this normal? After running the (now warm) amp and turning off/on a few times, relays engaged fine.
Just to confirm the behaviour, I put the amp outside to cool down (10 degrees celsius), took the amp back inside and powered up….same problem…relays cycle 3-4 times, and then capture. This amp only likes room temp.
Has anybody had this problem or similar? Can anything be done about it ?
