dr.mabuse71
Hi,
I have problems with the input selection of my NAD3020i.
The Aux/CD channel is crosstalking to the other channels.
Description of the problem:
If only the Aux signal is running:
1) I select Tuner as input, signal is as loud as if I select Aux
2) I select Phono as input, signal is a little bit lower as if I select Aux
If Aux and Tuner signals are running
1) Aux input selected: everything is ok
2) Tuner input seleted: I can hear Aux and Tuner signal mixed, both same level
Tape monitor selected:
all is silent (as it should be).
Has someone a hint for me ? Read something about "mute transistors" ?? Or the 100pf ceramic inputs ?
THX for your help,
kind regards, Michael
THX for your help,
