Hey there,
I'm actually planning the recap of this little amp but the one I bought it seems it was repaired at least once and the ouput transistors were replaced for different equivalent ones, it has only 1 original RCA transistor, therefore I would like to use the closest possible to the original ones..
- Is it worth to buy used ones original RCA on ebay or there is a big risk of getting counterfeit ones?
- In case it worth to buy newer ones, I checked on Mouser and Digikey and they don't have the original ones because they are not manufactured anymore (MJ2955 and 2N3055) but they have the newer versions of them MJ2955G and 2N3055G from onsemi, do you guys have a clue whether this newer versions can be used without altering anything in the circuit?, I checked the datasheet between the original ones and this "G" versions and they don't differ in basically anything..
Thank you!
Thank you!
