Eastham
More Class-A than ever!
Few days ago I plucked myself a non-working Nad 3140, seller described it as "nothing working".
Upon cracking it open I found quite a lot of dust and nasty, brown grease everywhere, cleaned the dust out with my hoover and a paint brush because I didn't fancy walking out in the rain to my shed where my air compressor is, I'm going to wait for a dry day to hose off the grease with PCB cleaner or something brake cleaner maybe?
All nice and clean.
Upon inspection I found some caps that look like they got very hot and some nasty glue that turned black... one was bulging and one of the 470µF 63V caps had vented.
Replaced all the bad caps I could with ones I had to hand and orderd the ones I need.
Now, onto the problem and what was causing it. I noticed with headphones I could hear faint signals with the amp turned up to max, seeing that both channels where effected I thought it was a pretty good chance it was a power supply issue, so I cracked out my multimeter and found I was missing the -21v rail for the pre-amp, a little probing around and I found a bad trace that was hidden by one of the chassis brackets, this trace connects R623 to R808 which feeds Q808 which regulates the -21v rail, bridged the two solder joints and she fired into life!
Cap deathtoll so far.
The blackend caps and the swolen cap all measured no capacity and I could actually measure resistance on them, 3Mohms on that swollen cap and 25 - 35Mohms for the blackend ones.
I could re-cap this unit but eh... Maybe later, sounds pretty fantastic right now, more updates when the rest of the caps come in.
All nice and clean.
