The NAD 3155 uses the Fujitsu 323D024 relay for the speakers, which is long discontinued. It has 6 connections, four pins close together and 2 pins at about the mid point of the relay. The mid point ones are the speaker outputs, the next set along (not the set at the edge of the relay) are the coil (24v) and the set at the edge of the relay are the inputs from the power amp.
A good replacement is the OMRON G2R-2A-ASI-DC24 (mouser 653-G2R-2A-ASI-DC24), which can be mounted in the subframe of the NAD and secured with a cable tie. The connections to the OMRON are pins 1 and 8 are the coil (there is no coil polarity), pins 3&6 are input and 4&5 are output to the speakers.
I have attached a couple of photos of the installation for reference and to assist others, as when I searched I could not find this information.
Peter
www.quirkaudio.com
Peter
www.quirkaudio.com
