Zeus12
Greetings fellow audiophiles,
Got the typical Relay "symptoms" on this NAD 319 amplifier and would like to know if it´s worth trying to clean the Speaker relay or better to put a new one in. Seems to be a very common issue with NAD amplifiers. It is in excellent condition, cosmetically looks new and the insides--apart from the dust--are all original.
1. There is more than one relay in there but I would imagine the one that needs to be changed is the 48VDC one (DEC).
2. How do I open the DEC relay? Been trying to remove the black cover but it´s not coming off. Is it worth trying?
3. From what I have read, the Omron G2R-2-DC48 would be a perfect replacement (drop-in) for the original: This is the one I found on mouser:
https://www.mouser.es/ProductDetail...J2a4iNJSvxwI2yjA7GvPV-b78hE1fk-YaAjA3EALw_wcB
Should I remove the power board--looks like a pain--or better to remove the bottom cover? The bottom cover has 2 separate parts to service the left and right channels but not for the PSU side. Looks like will be a time consuming endeavor.
Appreciate your help guys!
