Mark Dallmer
Hi, beginner here, so please bear with me!
I have a NAD 705 receiver which when switched on makes fairly loud "pop" noises on the left channel, and the right channel most of the time only comes on after shortly cranking up the volume knob, then crackles quite a bit. After playing for about 10 minutes both those symptoms go away and it sounds really nice. But even at that stage I can reproduce the pops on the left channel by tapping the device anywhere, but most pronounced at the front.
Opening it up I tapped inside with a plastic tool and I suspect the culprits are the transistors mounted to those C-shaped black heatsinks (there is to of them side-by-side in the left lower area of the board, looking form above). Also one of those C-shaped heatsinks gets much hotter than the other.
Now the questions:
1. Am I right in assuming the problems must be bad soldier points, as the symptoms go away when the receiver warms up?
2. How likely the transistors are damaged, considering that it plays fine when warmed up, IOW is this fixable by just re-soldering or would I need new parts?
3. The right channel not switching on at startup would likely be a relay being defective? Would that also explain the crackles (which also go away after time) or is that related to something else?
Thanks for any suggestions!
Regards - Mark
Now the questions:
Regards - Mark
