Bought an NAD 7140 off ebay a few months ago... and apparently didn't read the listing closely enough, as there was a note in the listing it would occasionally fail to turn on. Wasn't a real big deal during summer/fall, as if it failed to kick on initially you could just leave it on and it would start working within a few minutes. As we've gotten further into winter (house is a few degrees cooler, generally, so maybe temperature related?) it's been happening far more often, and on at least a couple occasions took a lot longer to warm up (like 30+ minutes) before starting to work. Sometimes it will kick on and off a bit as it transitions from not working to working... once working it seems fully functional but it's mainly getting used in the living room to play music for the kids so not pushing it very hard or anything.
I have a moderate amount of experience with general electronic stuff, however have not done a lot with discrete BJT/FETs and what I have done was a couple decades ago... so I understand the general theory of operation but am pretty rusty on specifics and am not real knowledgeable on testing/troubleshooting. Schematics in the service manual I found are taking some effort to figure out what's what and how everything actually works (for example I'm still baffled what actually drives output relay as I can't find that anywhere).
Opening up the case, electrolytic caps all look OK visually (no bulging/leaking). There is some heat discoloration of the pcb (not scorched/black but definitely darker discolored area on the component side) that seems to emanate from Q903, and to a lesser extent also some discoloration around Q901 and Q902. All these relate to the +/- 43V supplies, which seems to run the power amplifier section. Screenshot of relevant section of the schematic with a red circle on Q903 and measured voltages included below. +43 rail measured a little bit low at 40.8 but not sure if that matters(?). -43 was much closer at -42.95, however checking in AC mode (using Fluke 87V) showed 45mV AC--which seemed like something not working properly, especially given that Q903 is in that part of the circuit.
When it cuts in/out I *think* I can hear relay click, but am having trouble reliably reproducing the failure mode with the receiver opened up. Some stuff I've read seemed to indicate that the relay in these was just related to power on/off rather than having any protection function? I haven't been able to catch any of the power supplies doing anything weird, HOWEVER there have been a couple times where the receiver was cut out and when I tried to measure -43 supply traces it would cut in and start working... so possibly putting the DMM in the circuit is somehow changing things enough to stabilize whatever is going wrong? At this point I'm also not ruling out something weird like a flaky solder connection or a trace problem, as I've seen a few reports of those types of issues on these.
Any advice or insight from someone more knowledgeable / that's been into one of these before on how to proceed diagnosing / what to try to replace? Pull Q903 out and see how it measures? Also partly looking for speculation of what's cause and what's effect--is failure of Q903 likely to be source of the problem, or is that running hot more likely a result of something wonky with Q902 or elsewhere? Would power supply flakiness lead to complete cut-out of the output relay or is that more likely a separate issue?
I'm probably going to keep trying to reproduce the issue with the case open for a bit, so will add replies if/when I find anything further. I do have an oscilloscope I can get out, also, and could potentially set that up on the -43V supply to see if I can tell more about what's going on at power-up or with the AC/noise if warranted.
