marcthisdate
Where’s the confounded bridge?
The saga of the 7155 continues... Quick recap, I bought this knowing there were going to be issues but figured it would be a good project for the summer. Cosmetics were good and the price was a steal. It was sold as having no sound and of course it didn't. Also noted it was missing its jumpers so borrowed a pair from one of my other receivers and.... Great sound on the right channel but nothing on the left. Deoxit the daylights out of all of the switches and knobs but in the end it was a cold solder joint on the volume pot. Reflowed that and I was back in business.
Next up was testing the sources so hooked up a dipole and tried to get in some FM first. FM seemed to come in ok but not in stereo and never more than 2 bars on the meter. I have a 7140, using the same antenna in the same position and it gets 4 to 5 bars and stereo in the same spot so figured it was something with the tuner. This one I solved by adjusting the Stereo Switch Threshold and voila, I now have more bars and Stereo.
So now onto my current issue. Once I tune to a station and let it play for awhile (a few minutes, around 5 to 10), FM will go to full static. No bars on the meter and the Stereo indicator is dark. AM plays fine when FM is out, as does everything else. If I turn it off for awhile and let things cool down, it will come back none the worse for wear but will always go back to static at some point.
I'm thinking heat is probably the cause. I tried to reflow the solder in the FM pack components thinking maybe cold solder point of two but the issue persists. So, I'm looking for ideas on where to look next.
Appreciate any help you good folks can give...
