I finally got around to digging into a 7225 receiver that had blown a few years back after doing gentle office duty. What I found was that the power transistors for the left channel were blown together with a couple of the smaller transistors in that channel. I replaced all the blown components with devices I had on hand. While I don't have a distinct memory of where I got them, what I do remember is that the smaller devices (2SB649A & 2SD669A) are true OEM Hitachi components. I suspect that the power transistors were purchased at auction with uncertain pedigree.
Here's the problem: It works but sounds like crap!! Gone is the resonant bass that I recall and is obviously present in another NAD piece I have going at another location. I know the "NAD sound" since I've always had one running somewhere. Unfortunately, this one now sounds like music from a tin can!
Before I cracked it open I powered it up to remind me what was wrong. The right channel was fine but, as I've mentioned, the left was kaput. After replacing the cooked parts I performed the amp adjustments per the service manual and the voltage measurements were well within spec. Still, bass is extremely anemic to non-existent. The LOUDNESS button helps but I shouldn't have to go there. What gives?
If the consensus is that the (possibly fake) power transistors are at fault, then can someone recommend a reliable source for bona fide devices? I think DigiKey carries what I need but the options have me a little thrown. Guidance in this regard would be appreciated!!!
