Hi all,
Recently purchased a known bad NAD 7240 PE owner saying the fuse blew. He said previous owner said it was working, he plugged it in and said a fuse blew and his left speaker blew. I recently purchased a working NAD 7130 replaced all display digits and full recap except the large capacitors (didn't sound any better but now tuning speed is 50 times faster). Liked it so much I wanted to try and fix this 7240 PE.
Opened it up for a visual check and fuses were fine but R459 was completely burnt. Also noticed the emitter of Q25 was detached from the solder pad. Figured this was the problem so replaced R459 and resoldered Q25 emitter. RH channel was already working ok.
- Power on and R459 smoked again. Decided to dig deeper (not deep enough I would realize). Found Q427 shorted base-collector. Replaced R459 and put in something similar for Q427 (was hoping I could confirm there were no other problems).
- Power on and smoked R459 again. Decided to check all transistors in the LH channel. Found Q423 B-C short, Q427 B-C short (again), Q429 C-E short, Q433 all 3 legs shorted. All other transistors and diodes were OK using a diode check on my meter and comparing with RH channel. Ordered replacements and waiting.
Could the open emitter on Q25 have caused all this?
Can I power up with these transistors removed to check some voltages or do I risk blowing up more components? I assume power supply is fine since RH channel works well.
Will the light bulb limiter help to not blow up new transistors? Or does that only work to avoid fuses blowing?
My power amp section has multi-turn trim pots in place of the single turn ones. Is it possible this is factory or did someone change them.
Any advice would be appreciated before I blow up more transistors. I really like the 7130 and this is newer and a bit more powerful so I'd really like to fix it.
Thanks,
Thanks,
