NAD Amplifiers
Cylontymany
Could someone recommend an NAD amp or integrated that is common ground and has around 400wpc into 4ohms been looking at the C370 but I am sure there are plenty of other good ones too? I have the 1155 preamp looking to power Polk SDA 2b and Cerwin Vega DX9s
i have 2 2200 pe and luv them
they were recapped when i got them
many say to avoid the pe but i've never had an issue
i have never used them bridged
they have tons of power
I would avoid the C370. I bought mine new, had it repaired twice for the same problem, and now it has developed another problem. I think it is a known problem child, although it sounds good.
If your C370 problem was the protection board (zener heats the caps and kills 'em), the common fix isn't really a fix. The problem is heat is conducted through the zener leads, through the traces, and right into the caps. They don't last very long. The problem is not proximity, as is commonly thought, and moving the zener to the opposite side of the board provides little improvement. What you have to do is prevent conduction. That can be done in several ways. Space in front is limited, so I put the zener in back, but put long copper heat sinks (sheet metal strips) on the leads. In hindsight, a better solution would be to attach the copper strips to the zener pads, then solder the zener to the strips at the other end. You have to get rid of the heat before it gets into the traces on the pcb. You also have to heat sink the zener, as they rely on the leads to dissipate heat.
Why are you looking at any of these? Far as I know none comply with your power request.
If you bridge them to get the power then the common ground requirement is a fail. Even if the amps are common ground in their normal state, once bridged they are no longer common ground relative to each other.
I've only owned two NAD amps - The 2700 THX and 218 THX. Both are great values. I prefer the 218 and still use it to drive the subwoofer in my HT.
I've owned several 2200's and 2600a's. The 2200 is better, IMO. Not a real fan of either Power Envelope (dual voltage rail) or Soft Clipping. Both are power management schemes. I prefer good old fashioned heavy metal amps to take care of my power needs.
I bridge a 2700 to power a 400W, 4 ohm kicker comp vr sub. Great combo, the NAD has plenty of power for this (unlike a bridged luxman m120a or sony ta-n55es).
I know someone will correct me if I'm wrong, but bridging the amp and then using it with common ground devices such as the polk SDA, switch boxes, etc. will damage the amplifier.
