TrevorBarten
Well-Known Member
According to the previous owner it was working but suddenly they could hear pops from time to time via the speakers until one day there was a very loud pop and it stopped functioning properly. I tested it and it seems like the problem is limited to the pre amp as the power amp is working fine if I use a seperate pre amp for testing. If I do try the pre amp it outputs static and a very low volume audio signal for one of the channels. So does anyone have any experience with similar issues? My first thought was checking for shorts between the collector and emmitor for the transistors but could this actually be the issue? And if it is what other components should I check and replace?
