i'm sure someone else with with better explanation will chime in here
some amps especially pro gear need the higher output pre's to achieve their full output power
this would also be handy if feeding to multiple amps via splitters
That's funny, considering the Crown XLS amps 1.4V (or 0.775V option on the 2nd gen) input sensitivity which is right in the wheelhouse, or less in the case of 0.775V, than many, perhaps even most, non-pro amps.
It's fine to use them if you need a stronger signal to a downstream amp.
What you may find using them in lieu of the normal outputs, if the amp doesn't need more signal (gain) from the preamp, is the system plays loud at a very low setting of the volume control and has little usable range of the volume control.
If the connected amp has its own level controls as some do, and as many powered subs do, they can be adjusted to lower input sensitivity (lower net gain) to compensate for the higher gain from those pre outs.
My point isn't to make such a huge deal out if it. If it works to your satisfaction that's great, and it's not like anything will be harmed.
I just often read comments about pro amps being hard to drive or requiring something above and beyond to drive them. Most often it's just not the case, that's all.
The main points to look at are the preamp output impedance, power amp input impedance, pre out voltage and power amp input sensitivity.
For the impedances, a general rule of thumb is to maintain a ratio of 1:10 or more between pre out and amp input impedance (generally that goes for any connection between input and output).
Then, if you want to be able to push the amplifier to full rated output, then whatever is feeding the amp needs to be able to produce at least the voltage given in the amp specs to produce full rated output. In the case of the DriveCore that's 1.4 volts. For the DriveCore2 the input sensitivity can be set to 1.4V or 0.775V.
