Martin Rola
I have a C160 preamplifier, and I just noticed something odd. When I use a Y-cable out of either of the preamp outputs to connect to a subwoofer that has a single RCA input, the amp switches to a mono mode (or at least a partial mono). For example, if I pan all the way to the left, it works as expected without the Y-cable attached. As soon as I connect the Y-cable, both speakers get sound. The same result happens even if I use the passthrough output on the amplifier (bi-amping with two Parasound HSA-750s in stereo mode). The effect occurs on both the high frequency and low frequency connections to the speakers. If I use a single cable out of only one of the outputs, the system operates as expected. It happens even if the Y-cable is not connected to the subwoofer, so it is not triggered by the sub. I've tried various Y-cables as well. Does anyone have any idea what may be causing this?
