NAD3020 amplifier blown one channel.
Simon H
Hi,
Wanting some help with a repair of this old NAD3020 amplifier that has blown the left channel.
I have hopefully attached the relevant schematic. Soft clipping is off and Pre-out / Nor in connected.
When I got it the right channel played fine, but the left had no output and a -10V DC offset (from memory). The MJ2955 output transistor Q617 was blown, I had one spare, so put it in. Still no dice. Noticed R651 between the emitters of the driver transistors Q611 and Q613 was black but still measured 180ohms, but I replaced. Also R629 1W was slightly discoloured and it's neighbour R631 was black. R647 was also slighly burned. The PCB was blackened under R629 and R631. I replaced R631 and R647, but R629 was still reading good and was 1W. I guess it gives a clue as to what part of the circuit where the current is flowing more than it should. The other side looked fine. Someone had replaced R642 on the right side, but no signs of thermal stress.
I then went back and looked at the transistors in the signal path. I pulled them and used a component tester. Q601 was faulty, but but Q603 and Q605 were fine. I replaced Q601 with an ebay one, but still nothing, and the R651 I had replaced was getting hot again. I pulled the drivers Q611 and Q613, and also the biasing transistor Q609, which were also faulty with the component tester. I checked Q605 and Q607, which tested fine. I had ordered some BD237 and BD238 at the same time from ebay, so put them in. I had checked most of the resistors in circuit, and the voltages up until Q601 to Q603 were fine, but thereafter they were way off. Unfortunately, as I was testing and then not one time I forgot to put the DBT in circuit, and I blew everything beyond Q607 again. I attributed the fact it wasn't working to perhaps less than satisfactory parts from ebay, but they were cheap and quick (from a UK seller). I have since ordered replacement transistors, and have everything except the 2n3055 and MJ2955s.
I think there are still problems with the circuit, and I took advantage of the fact I had isolated a lot of the circuit by not having the transistors in. I had also noticed problems with the +ve rail voltage.
The first thing is I don't get the diode drop from D603, except the the cathode end of the diode - that screws up the voltages for the emitters for Q603 and Q605, and the collector for Q607. So I do not get the 0.5V drop across R627 (390ohm) or R639 (68ohm).
The Q603 collector -ve voltage is a mistake I assume.
The voltages on the schematic are otherwise ok up until Q605 and Q607 (Darlington pair). Q601 BEC - 1Vbase, 0.5Vemitter, 31Vcollector Q603 all read around 31V, but varies a bit by 0.3V. Not seeing a convincing diode drop Vbe...
Q605 B : 31.03V, E : 31.2V C : -26.12V
Q607 B : -26.12V E : -26.12V C : 31.23V
I'm not entirely sure where the voltage path is to the -26.12V (marked as -25.4V on the schematic). All 5 of the transistors after Q607are out. It can only be via R643, R645, R647, then R649 - I could put back Q611 and Q613 with Q609, but it would be good to understand how putting them in would decrease the current flow to the negative rail.
I replaced C625, which made no difference. The only thing that helped was lifting one leg of R647. Think there is only 3 resistors that join Q605 and Q607 to the -26V negative rail. I have replaced Q605 and Q607 with ones from Farnell. There was a thread where despite the Q607 seemingly being ok on a tester, there was some 'leak', which resulted in the similar negative voltages I am getting.
I'm trying to understand the circuit and the principles behind it. For instance the lack of 0.5 voltage drop from +30.7V supply rail to +30.1V on the Darlington pair ? Is the problem that I have not put all rest of the transistors in, but I can't see how they would feedback. Unless it is that 0V connection between the emitters of the output transistors ?! And I'm now seeing that I slightly misread the schematic, thinking C625 provides a path from Q605 collector and Q607 emitter to the minus rail.
What am I missing ?
Thanks for any help or suggestions.
Simon
I would be grateful for some help.
I have attached the voltages I have.
I have removed Q611, Q613, Q615 and Q617.
It is slowly dawning on me that they may have some influence on the voltages I am getting.
I am planning on using 460ohm 2 watt resistors to join the bases of Q611/Q613 to emitters of Q615/Q617, as I don't want to risk blowing the output transistors. There was a thread I saw somewhere where that was suggested.
I have checked Q601 Q603 Q605 and Q607 on a component tester, also with identical substitutes from Farnell. Q601 was originally blown.
Q601 looks like it is working as expected with correct voltage, although the base is slightly high.
Q603 is working i.e. it is turned on, but all it's voltages are a bit high, which then puts the base of 605 too high so it does not turn on, so there is not the correct voltage drop across R639 and I get -26 on the collector as is got no connection to the positive rail.
What I don't understand is:
1. why there is only 0.1V drop over R627, which is 0.2mA. I assume that may be DMM error, and there is no current flowing, so the transistor is not actually on.
2. why the voltage goes up from 29.5V at the cathode of D603 to 30V at the base of Q603.
I have checked pretty much all the resistors, which seem within error. I have only checked a one of the non-electrolytics, C605 as the voltage jumps up from 29.5 to 30 on the other side of R619 and R621.
Is the NFB important getting the correct voltages. Currently it is floating as Q615/Q617 are out of the equation. But there is only one DC connection for this via the emitter of Q601, and I can't see how this would affect all the other voltages I have going high. Of note there was a lot of heat around R629 and R631, with blackening of the board below them, so there has been some mishap through that area which I assumed was due to at least one of the output transformers blowing and shorting something.
The right channel is fine, with all voltages correct.
I am always learning and have learned a bit more since posting my original endeavours 5 days ago. But still lack the experience and knowledge to do anything quickly, and without some degree of futility....
Thanks in advance.
