Naim, Rega Aria, and Thorens td160 super
Zackh2o
I have a system which will consist of Naim amp, pre-amp with Rega rp8 turntable and aria phonostage. Will the thoren td160 super plug into the aria mm connections with the rp8 connecting to the mc? Allowing me to use one phonostage for both turntables. Thanks
Why not? They are separate amplifiers in the same box. Even if they were not and the MC side had a transformer, the switch would still take care of that.
Let me expand on that by asking you a question. .
Do you have a Moving Coil cartridge or plan to put on the RP8? If that is the case, absolutely you can do that. If no, it won't work.
I have a NAD MM/MC preamp that I do that with on occasion.
