As Nakdoc posted ( I still have to send you that extra idler tire), the belt kit is available from Marrs. The cam belt is actually super easy to replace, takes about 5 seconds once opened. The capstans belt is a little more involved, maybe an hour for the AR. Only the flip belt is a pita, takes about an extra hour, if you're doing the capstan. The idler tire is about impossible without the right tools, as you have to CAREFULLY remove the tiny metal "C" clips from the nylon posts, and I would really fear that I'd break a post and then you are SOL. You also have to remove the tape head pivot bar, which can change your alignment. Since the FF & RW on my current 505 is lightspeed fast, I can assume the idler is still in good shape. I did not change out the OEM belt for the current Marrs belt, because he annouced that he would have a less expensive (than ESL, which gets $50) exact OEM belt available shortly. Since I was literally in the midst of changing belts when this happened, I found out that not everyone on Naktalk was entralled with his "original" mechanism replacement belt. And because my original belt sounds great, and has no visual signs of distress, I cleaned the capstan flywheels and put the old belt back on. I can't stress enough how much easier it is to lube the shafts with the pen style teflon oiler (like $3) from RS.
