Nakamichi BX 300 help needed
kahler
Howdy ya'll,
I just purchased a Nakamichi BX 300 off of craigslist. Upon inspecting the deck at the guy's house, I noticed that it was having trouble rewinding, I figured it was an idler tire issue (I have owned a bx 100 and bx 125, changed the tires on both). So he sold
it to me for way less and I was on my way thinking it would be an easy fix.
Later at home, I popped off the vanity plate and I was surprised to see that this BX 300 has the gear drive idler, not the rubber tire. This concerns me because now I don't know how to fix it!
Does anybody know what the issue is with my tape deck? It played and FF fine when I got it (last night), but now it won't do anything with a tape in.When I hit play, it makes a short, loud rumbling sound and that is it. This deck is in really nice cosmetic shape and I want a 3 head Nak so bad! Unfortunately I do not have a ton of funds to throw at this. If I can't fix it, it might go up in BT.
Thanks for reading,
Kahler
gently, carefully remove the motor driving the idler and clean it physically and electrically.
for advice go to naktalk and tapeheads
if things go south, sell the gear mechanism.
With the gear drive at least you have a modded one ( which was the factory mod from the idler drive, Nak sold a mod kit at the time) Check as was mentioned previously , see if the mechanism is moving. The mechanism control motor has a high failure rate and also the idler motor is some times iffy.
Your cam motor has probably dead spotted. (common, very common) The cam motor has a worm gear which turns a larger white gear. Hit play and give that worm gear a little nudge. It will fire right up and probably play for you. But thats the problem.
