Had the same problem with my RX202. After reading much from this forum, I decided to change the main drive belt. In fact, I even ordered tire for the idler and a belt for the reverse function. But come to find out, my unit has geared reverse function and eject function. So all I needed is the main drive belt. Just to repeat, this is originally owned by me and bought it back in the late 80's. It was working perfectly until about two years ago wherein it would play for about a second or two and then reverse then stops. Changing the drive belt fixed this problem. However, after testing with a pre-recorded tape, no sound is coming out of the unit. The output level indicator lights stays at the bottom led light and no sign of output signal even with the slider adjustment to the max level.
So I tried doing some recording and the record level lights were working in accordance with the slider adjustment. However, when I played it back, there was no sound coming out of the unit nor there was any indication of output signal from the output LED light levels even with the slider at max position. Could this be a bad R/P head? Any insight is truly appreciated. Sorry to hijack this thread but it seems the problem have similarities.
