It's a two-head deck that has a unidirectional autoreverse transport that flips the tape around to play the other side. If you need autoreverse, it's the cheapest Nakamichi that has it; if you don't, it's one more thing to go wrong, and a bit of a pain to work on.
I'd run it through a bunch of FF / REW cycles, as well as direction change cycles before buying it.
Personally, I'd recommend a non-autoreverse Nak instead. A 600 is a great sounding deck with a mostly mechanical transport and specs that beat most other decks. The 480 sounds great once you standardize on a tape formula and tune the bias and record level (inside adjustments); at this age, they'll need new belts, and these require original ones. I'd stay away from the BX- series decks, as they usually need the idler wheel tire replaced or they won't FF through a tape, and will be frequently stopping.
I'd put value of a well-working RX-202 somewhere between 75 and 150, but be prepared to find surprises.
