Greetings, I'm currently trying to save a Nak TA-3A receiver that was going into protection at start up.
I'm familiar with the issues that heat can cause with this unit in regard to solder joints so those were addressed first.
At first power up the PS relay engaged but the speaker relay clicked multiple times and into protection it went. With the unit on a DBT it came out of protection. The the voltages from the supply board were a little low so I recapped the power supply board which brought all voltages up to acceptable levels. After checking the voltages on all TR's on both amp channels I found the left channel voltages fine and the right channel were almost all not fine. The problem was right channel R309(R), which was open. I replaced R309 on both channels. Now both channels TR voltages are in the green except the connected collectors of Q316 (L&R), which the SM shows should be [+40mV] but measure +5mV. This also puts the base of Q317 [+40mV] at +5mV and the emitter [+29mV] is +80mV, farther away from spec than I'd like but it comes out of protection off of the DBT. I also checked the Q206-Q211 "18 Volt" circuit and all voltages look good.
There is only a Bias current adjustment for the amp section of this receiver and it's supposed to be set at 25mV +/- 5mV. I found a three pin computer connector to attach to CN-32 connector as recommended so both channel measurement points can be taken easily and made the 2 RCA shorting plugs for the process. After substantial warm up, with the bottom and top cover installed, both channels stay at a pretty steady -4 mV and do not respond to bias resistor adjustments.
I've measured both channels' variable resistors as well as all emitter resistors out of circuit, as well as R's 391 / R310 / R321 / R322 / R330 / R344. I also replaced Zener diodes zd301,302,303 (both channels) & D304 as well as electrolytic caps C301/C306 both channels. The voltage drop over TH301 is correct and TH301 measures approx 92K ohm (in circuit) room temp - and drops to zero ohms once the unit warms up.
There is a LOT here on AK about problems with the Nak TA2/3 which I have attempted to read all of but nothing seems to shed light for me on what my particular problem might be. The unit passes audio just fine and sounds great but the bias current not being able to be adjusted just doesn't sit right with me. I'm happy to post any voltages and answer any questions about what I've done so far and would appreciate any input and or suggestions.
Thanks!
M->
https://www.hifiengine.com/manual_library/nakamichi/ta-3.shtml
Thanks!
M->
