jjbunn
Member
My Nakamichi TA-4A works very well, except for one niggling defect: the remote control of the volume does not function.
Voltage is appearing at the motor terminals when the remote control up/down volume is pressed: -6V for down, +6V for up. So that looks fine. I think the motor is dead, as it's open circuit across the terminals which receive those voltages. The motor doesn't work when applying bench supply across those terminals, either.
The motor is the top right cylindrical unit shown in the photo. It is attached to what I assume is a gearbox (rectangular metal box), and the volume/balance pots are just below.
I can't find any motor part number reference in the TA-4A service manual, so I'm a bit stuck. Is it probably a stepper motor of some sort? Any ideas on what might work as a replacement would be most welcome!
