Name these JBLs?
Zonker92
All shiny and chrome
I realize this is a tough one, but our local church is replacing these JBL PA speakers; I'm seeing them tomorrow. Just wondering which model they might be. Apparently, they have 12" woofers. I'm having trouble finding better photos on-line. My gut tells me they're probably not worth pursuing, but I am curious. Thanks.
Thanks, but those models both look too small. I’m going with the MP212, just to speculate from Google Images. I should know tomorrow and will report back then.
Hard pass: They turned out to be a fairly generic model called the SF15, and the seller was asking way too much anyway. Although the horns would probably be good for eWaves.
http://www.jblproservice.com/pdf/Sound Factor/SF15.pdf
iu
Sound Factor line is budget to mid level PA / Sound reinforcement/ DJ type gear, lots of sound for the buck, reasonably transportable and reliable. Most setups I’ve heard are really really hot mid and HF wise because of the damaged hearing most DJs have IMO. The poor audience / dancers that have to be in front of the speaker’s horns are blasted into the night. Whenever I go to an event with these types of setups, I bring earplugs or fashion some from rolled up Kleenex to preserve my hearing.
Nothing hugely wrong with this series, but nothing special. Probably could be made to sound decent with careful eq and good amps, it not worth using in a home environment IMO.
Annnnd ... now they're sitting in my side yard, with really beefy universal wall-mounts bolted to them. Our family friend donated money to the church and got these for me in return; such a nice guy.
No idea what to do with them, but the waveguides are the ones Zilch used for most of his eWaves. I think the horn drivers and woofers are crap. Whether or not I upgrade the drivers and crossovers, the possibilities include:
  • Hang in them in my garage;
  • Hang them out back to please the neighbors;
  • Bring them up to my friend's ranch;
  • Part them out and keep the horns;
  • Store them and haul them out for parties;
  • Give them to someone who could actually use them.
Our friends have a huge yard (3 acres); they really could use them for parties.
NEW LOWER PRICE... WAS $299.99! On Closeout... Limited Quantities Available! This trapezoidal, 15" speaker system is at home in live sound, dance music and speech reinforcement. The SF15 is equipped with a 35mm pole mount socket, and an impressive peak power capacity of 1000 watts. 250 watts continuous.
FEATURES:
• JBL 15" low frequency driver with a 64 mm (2 in) diameter edgewound ribbon voice coil which provides more cross-sectional wire area in the voice coil gap than round wire designs, for greater efficiency and power handling.
• Ferro-fluid cooled compression driver with titanium diaphragm improves high frequency performance as well as system reliability.
• The advanced network topology crossover design shapes the frequency response to deliver coherent summation in the crossover region.
• High-voltage capacitors and inductors with massive cores and heavy gauge wire enable the crossover network to handle high power without saturating.
• Progressive Transition' high frequency waveguide provides superior coverage control, reduced distortion, and smoother frequency response.
• The rugged, acoustically superior enclosure is constructed from 19 mm ( in) MDF (Medium Density Fiberboard) using advanced adhesives and mechanical fastener technology for extreme durability and improved low-frequency performance.
• SonicGuard' protects the high frequency driver from excess power without interrupting the performance.
• Non-resonant, all-steel handles are used.
• Attractive 18-gauge perforated, steel grille protects components from damage.
• Cast aluminum, 35 mm pole-mount cup for stand mounting.
SPECIFICATIONS:
• System Type: 15" 2-way, sound reinforcement speaker
• Frequency Range (-10 dB):2 38 Hz - 16 kHz
• Frequency Response (3 dB):2 50 Hz - 12.5 kHz
• Sensitivity (1w/1m): 98 dB SPL
• Nominal Impedance: 8
• Power Capacity:1 250 watts
• Peak Power Capacity:1 1000 watts
• Maximum SPL: 128 dB
• Nominal Dispersion: 90 x 50
• Crossover Frequency: 1.6 kHz
• Dimensions (H x W x D):3 698.5 mm x 459.9 mm x 431.8 mm
(27.5 in x 18.11 in x 17 in)
• Weight: 27.4 kg (60.5 lbs.)
• Shipping Weight: 30.4 kg (67.0 lbs.)
• High Frequency Driver: JBL 2412, 1" exit compression driver mounted on Progressive Transition' Waveguide
• Low Frequency Driver: JBL M115-8A
• Input Connectors: Parallel Neutrik Speakon NL-4 (x1); " TS phone jack (x1)
• Enclosure Construction: 19 mm ( in) MDF (Medium Density Fiberboard); with glued and mechanically fastened joint detail; covered in black carpet.
• Grille: 18-gauge, powder-coated steel
• Mounting & Suspension: 35 mm, cast aluminum pole-mount socket
unless you plan to have some parties, give them to your friend and let them deal with them. You have many other speakers to bring outside with much better quality sound.
Life is too short to store inferior speakers, we both know that all too well.;)
