good day everyone. a friend of mine gave me an old amp.a vintage receiver national panasonic sa-6800x. all is working fine except no lights at all.or the only light which work is the power indicator.i test all the lamps using a power supply and all are ok.i checked the cables for the connection and all ok, i checked also the two fuses on the near back and all ok.i checked the voltage for the line which supply power to the lamps and i got only 0.4 volts.suppose to be its 6v+ because the lamps are 6.3v 0.25A. any help please!!! thanks
