I have used the Rustoleum paint on several projects. If you use heat you can control the time required for the hammered look to appear and make it consistant across the whole cabinet. My wife hates it when I use the range.
John
Awesome...What worked for me on an AU-719: Krylon brushed metallic, oil rubbed bronze-satin on the case; Rustoleum satin, black on the rack handles. Looks pretty good for a rattle can job, the Krylon could be a little less metallic but it lays down smoother than the hammered paints.
Friggin awesome!Dupli-Color DE1651 "Cast Coat Iron" worked very well for me. It's an engine enamel. Other than being a bit lighter than the original, it has the perfect amount of metallic flake and sheen.
View attachment 1541884 View attachment 1541885
For the rack handles I used Dupli-Color DE 1634 Low Gloss Black.
My rack handles came out near perfect after sand blasting them with very fine sand.
Nice job! The trick with this paint (and perhaps with most other paints) is to do two light coats and finish with a final thicker coat. That gives a nice even finish.View attachment 1547910
I did as you suggested and I am impressed with the results, but I was considering putting a clear coat on and I was unsure whether or not that was a good idea or not, so I did not do that
