Hi.
Im new one here and i saw a thread about connecting one transformer to two seperate amps. Im in similar position so here it is... the transformer originaly IS from an old akai amp it has 24-0-24, 2x25w, 220v in, 2 capacitors were 4700mf 50v on the original pcb. The amps are both TDA7294 100w 36v -/+.
They are seperated, on two PCB's and have tree power input connections. For the one amp and the transformer conection is fine i know that much. Problem for me is the second amp. I was thinking putting one 24v wire on one amp and the other 24v wire on the other amp and bridging the ground/negative between amps with wire. The amps have 2200mf 50v caps. And image provided already connected. But not powered up yet.
