JimJ[VT];4783893 said:
I know 1:1 current baluns are used a lot in ham radio. Often times, it's just a "choke balun" formed by a loop of the coax at the feedpoint, reducing common mode signals on the shield of the coax.
A 1/2-wave vertical and 1/2-wave dipole aren't the same antennas. A halfwave dipole is just its horizontal counterpart rotated vertically, and you're right, it's still 50 ohms. The vertical is just a halfwave radiator with "nothing else" (in quotes because that's a contentious point, you need to have some kind of ground or counterpoise in the equation at some point)
Because of the coax feed. Doesn't have to be, though...a lot of hams (myself included, when I get around to it) put up dipoles fed with balanced ladder line, so it stays balanced all the way back to the antenna tuner.
There isn't really a need, but a few loops at the feedpoint is easy to do.
I did not notice your post when I made my post.
A dipole antenna is a balanced antenna regardless of the type of feed line.
A ground plane vertical uses a quarter wave radiator, not a half wave radiator.
A half wave dipole is so called because the entire length is approximately one half wavelength. Each leg of the dipole is a quarter wave length long.
Some of the vertical FM broadcast band antennae available on the internet are in fact half wave vertical antennae, with an overall length of about 58 inches or a little less. The coil used to match the impedance to either 50 or 75 Ohm coax provides a small amount of inductive loading resulting in a slightly shorter vertical radiator. The advantage of this type of antennae is a slightly lower take off angle than a quarter wave vertical and this will result in slight increase in the "gain" of the antennae.
A half wave (about 58 inches for the FM band) radiator used as a simple ground plane antenna without some form of matching network will not work up to its full potential. Because of the mismatch, the shield of the coax may function as part of the antenna and give the impression that it does in fact work.
Because of the skin affect of RF, a piece of coax connected directly to a balanced antenna actually functions as three wires. The center conductor, the inside of the shield and the outside of the shield.
The outside of the shield of the coax will act like an antenna, instead of just a feed line. That means it is free to pick up wanted or unwanted signals. In the case of trying orient a dipole antenna for the least amount of multi-path signal reception, this unwanted antenna will cause problems. Also since the outside of the shield of the coax is acting as an antenna, it is free to pick up noise along it full length. So if you have moved your antenna away from something like a computer or switching power supply so that it does not pick up as much noise, that move will not be as affective.
Having said all of this, when it comes to receiving an FM broadcast signal, sometimes a random "chunk" of wire will work well enough. But when conditions are rough, and understanding of antenna design will go a long way to improving your enjoyment of FM.
