Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
I am restoring a Concerton U547 tube radio from 1957. I need a diode marked SR 250 Y 130. Or a suitable replacement. I dont have a schematic or parts list. Its a very rare radio made in Sweden. Thank you for any help you might offer.
If it is a selenium rectifier and you replace it with a 1N4007, you will probably need a resistor to drop voltages back down. 22-68 ohms at 5 or 10 watts should probably do it, but you may have to experiment.
Thank you! I will try a 1N4007. This radio is very strange, in that it only has 1 diode, and it is not a bridge. Its only a half wave power rectifier for the entire radio. I didnt know they made radios without full wave rectifiers. It has 7 tubes all total and 4 speakers.
You find that on series string rigs that run straight across the power line. Be careful, it may have the chassis tied straight to one side of the power cord.
I installed a 1N4007 diode (only 1) and a series 150 ohm resistor. It drops 8V across the resistor. I also replaced all the big caps in the radio. It powers on! But it wont pick up any AM or FM stations. Just static. I dont know how to do an alignment. Guess I will have to take it in to a shop. Thank you all very much for your help.
Check the resistors in the set, pull each tube one by one to clean it's pins and the sockets. Also make sure the correct tubes are installed. I've run into that one a couple of times.
