Need experienced help choosing please.
ChrisAZ
I could use some help finding a decent turntable for under $300 if possible. This will be my first turntable and I have a several components I will experiment using it with. I’m looking for good bass and big rich sound. Aesthetics count too.
I’ll be using any of the following:
Sansui CA/BA 2000 separates
Sansui AU-9500 integrated
Marantz 2230 receiver
Setton 440 receiver
Speakers:
Original large Advents
New large Advents
Dynaco A25’s
KLH 23’s
Roger sound labs Elans
Pioneer CS a700’s
Some I’m considering are:
Technics sl 1950 - $200
Technics sl 1800 - $250
Dual 1219 - $250
Dual 1215S - $150
ProJect P 2.9 - $250
Rega planar 2 - $300
Pioneer PL-55DX - $330 Barely used, perfect condition
Sansui SR 2050C - $120
The Technics SL1800 would be my first choice. The 1950 is good too, but not as good. The Dual 1219s are very good, but MUCH more complicated mechanically. Even if they currently play, they should ideally be serviced before they are put into regular use. Unless it was very recently done, of course.
Be aware that this thread will be moved to Dollars and Sense forum shortly due to the links to Craigslist. Also, be aware, others may be watching the same tables you are and this thread will pop up on a search, and if we recommend one, they will snatch it up. With all that, The SL-1800 would also be my choice.
I see your point, thanks. I removed the links.
House with flooring conducive to "footfall".
Big dog running around the house.
Go for the Technics SL-1800 with the adjustable spring suspension. :thumbsup:
