Studying the TA-800 schematic because I'm using the transformer for something else. End bells are currently removed for paint and I can't easily hook it up to just measure this. I thought I already had, but either I did not, or I lost my notes.
Trying to work backwards to figure out what this winding's output voltage is.
Schematic bit here
so I have DC voltage at the - output of the rectifier at -25v. Some amount of voltage will be dropped across R13. Current through this should be darn close to 0.3 amps. The parts list says R13 is 1K, which means its dropping 300 volts. I find this highly unlikely. C23A is a 30 volt cap so it can't be seeing more than that, which means not more than a 5v drop across R13.
Can anyone confirm what the value of R13 is, or I can also work with the voltage coming out of the transformer, or the DC voltage across C23A.
basically just trying to figure out if there will be enough voltage for my bias supply with a bridge or if I need to make it a voltage doubler.
Appreciate any info available.
Schematic bit here
