Need help: Diode replacement HZ12-A2, GP10D
Kecap Manis
Hi All,
I need help with replacement for older diode in a circa 1980s amplifier. A few of the diodes leg was badly corroded (one is broken upon cleaning) by glue from nearby elco. I'm hoping to find a similar spec new replacement.
Hitachi/Renesas HZ12-A2 -AX in regulator section
Possible replacement:
a) Vishay TZX12C, this is available at Mouser,
https://www.google.com/url?sa=t&rct...tzxserie.pdf&usg=AOvVaw1YXbI2w7mt1wqOwv9A2_qB
b) NTE5021T1, this looks to be EOL
GP10D -AX Unknown make possibly Hitachi or Toshiba
Possible replacement: Vishay GP10D or RGP10D
Much appreciate if somebody could have a look to see if the possible replacement is a good substitute. Thanks.
Cheers,
Heru
its a 12v half watt zener, unremarkable, ands its 'error code' from the hitachi datasheet says it errs on the high side of 12 i.e. 11.9-12.4 possible range.
If this is for the regulated supply its likely 12v is needed here, so this being the future, any fine 12v half watt zener (or even a full watt) should do from mouser
