Need help finding parts to my Turntable
StevenMS
Hey, I have a Panasonic techniques SL 1610 I don't know if it's in Mk1 and Mk2 I don't know the difference. I'm trying to find the speed selector switch and pitch switch replacement please help and if you have any suggestions where to buy records at a cheaper price but good quality suggestions are greatly appreciated.
Perhaps just need to de-oxit the switch and pot. List your local for help on record bargains. They are sold here, but you must be a supporter...Try google Images, for info on MK1 or 2, or vinylengine.com.
Post a photo!
It's Technics.
The MK1 has the controls inside the lid. The MK2 has them in the black panel across the front outside the cover. It also says "MK2" on the front right. Plus, as was mentioned, it has Quartz speed lock control.
So I based off the information I was given I have an mk1. The three knobs on the front left I think I shorting out they work when they want I can never adjust the speed. Should I try cleaning them first or replacements. I'm new to vinyl so thanks for being helpful guys! Here are some pictures of the table and my phono amp and receiver.
For example, my SL 1300 MKI has speed control pots mounted on the surface of the plinth, and also further adjustments through hole under the platter by a flat blade screwdriver. You must remove the bottom for access to pots. Always consult your model's Owner's/ Service Manual for specifics. My 1300 is not Quartz locked... but plays dead on after adjustment/ cleaning.
Trust me on the cleaning of the controls. I also have a Sl-1610 Mk 1...though I haven't cleaned the controls on it, I have seen a simple cleaning with Deoxit work wonders on other equipment.
