So this amp finally burned up one of the output transistors on the left channel and since it has been repaired at least 5 times in the last 2-3 years by a 3rd party with who knows what quality replacements we decided to just buy the parts ourselves and change all 4 output transistors and all 4 drivers
Outputs
2SD848A
2SB758A
Drivers
2SD357
2SB527 (they were already replaced when my father got this amp, meaning doesnt have the originals anymore on either channel)
so as far as ive researched, for the outputs of this exact same amp one guy here on AK used pairs of MJE15030G and MJE15031G and he said it worked fine
my worry is that the originals are supposedly 80W of heat dissipation and the 15030-31 are 50W and this amp was driving some CANTON SE140 which on the back say 4-8 ohms (DMM reads 4 ohms on box terminals) so it should be outputting a little more than 40W and am worried they might overheat and die
(most of the time the amp was hooked up to a Sansui TU-519 with it its volume knob at aound 50% and the amps volume at a little over 1/4, aux input level was around 140mv max from and old phone, so its not like it was being driven hard often, only rarely)
but for the drivers ive no idea what to use, another person here was asking for the same pair of drivers but for a sansui and someone told him to use the same 15030-15031 but idk if there are better alternatives
any suggestion is greatly appreciated, the only caveat is that they have to be available and in stock on LCSC, because mouser and digikey the shipping cost alone to south america is about the cost of just getting another SA-3000 locally (over 100USD shipping)
Outputs
2SD848A
2SB758A
Drivers
2SD357
