theblackknight
Mikes off! No recording!
Hello,
I am working on a Setton RS-660 stereo receiver.
It sat for 15 years before I powered it up a couple days ago. The contacts were very dirty, so I cleaned them and now it works OK.
I also changed the PS caps on another Setton(the BS-5500 power amp) which drastically improved proformance. $90 worth of caps. it was absolutely necessary in this case though--they were oozing black gunk evrywhere. I also have another stock BS-5500(I have 2- a recapped and a stock) which doesn't sound nearly as good as the recapped one.
normally most people dont change them in vintage stuff. even though the RS-660 still works do you recommend it? would having the RS-660 sit like it did for 15 years dry out the caps?
also--the RS-660 flickers and buzzes for the first ~15 seconds after power-up. this is AFTER the protection has clicked off. then, it stabilizes and works OK. I'm sure this is not a power switch problem as the power switch was already replaced--the power switch was the "achilles heel" of the RS-660 and other setton receivers. it was a problem waiting to happen, every setton receiever I have seen either has a bad one or a replacment. my uncle(the owner of this RS-660 that Im fixing) said that it has always done this flicker and buzz thing except when he first got it.
Im thinking is might be a power supply problem. should I worry about it or just leave it and let it stabilize on it's own like it alway has?
Thanks,
Henry
Thanks,
Henry
