dogwan
Dogwan
Hey all, I have this apparently very rare MC board out of a mid-70's PSE Studio One preamp. Decided to start a separate thread since it's really just about the transistors, not the preamp itself.
I discovered the MC phono input was not working so I pulled the board out start testing the transistors and caps. Quickly found the complementary pair of transistors at the power input to the board were both toast. Normally if I can't locate a datasheet for a transistor I will look for another of the same to pull and test to at least get the pinout and determine if it's a NPN or PNP. This board is the only place these transistors were used in the entire unit.
So, my issues are:
I am also attaching sketches of the circuit. There are most assuredly mistakes, but I am confident of at least the general idea. And I paid particular attention to the two transistors in question (circled in red). I labelled the pinout on the connections.
So if anyone can verify ID, suggest replacements, and most importantly, tell me what the pinout (CBE, EBC, BEC, etc) should be based on the diagram?
Note: as you can see the pinout appears to be different between the complimentary pair. Also, the measured voltage between the positive and negative leads is 60vdc. When measured to ground it is +30 and -30, so I assume it is balanced. All other transistors were pulled and tested good. Caps all test decent.
thanks,
Dogwan
So, my issues are:
- I am not 100% sure of the transistor part #'s.
One says BC 340LA and I am pretty sure it is a BC340?
The other says 320L and suspect that it's BC320, but the only BC320 info I could find shows TO-39 (not TO-92 as shown).
- Unable to find dependable datasheets on either of these transistors (even if I was positive on the ID), so cannot be sure of the pinout.
- Unable to determine suitable replacements (even if I was sure of the ID).
thanks,
Dogwan
