AndyCares
Hey Akers. Hoping someone can steer me in the right direction here with the information I'm able to provide. I recently began working on a Pioneer SX-3700. Mostly replacing caps and trouble trannies. Anyway, I broke one of my own rules and replaced several caps and a few trannies before I was able to test on my DBT after each piece swap. Upon powering up, the 100W bulb lit brighter than I've ever seen. I narrowed it down to one piece, but cannot for the life of me figure out the source of the short. After identifying that I goofed and caused a short, I began backtracking and testing after each component removal. I finally narrowing it down to R334 on board GWM-159, which is a .22Ω / 2W cement resistor with one end on the emitter of 2sc2525 power train. When remove this resistor, the bulb dims to a normal level/almost totally off. If anyone could steer me in the right position, I would greatly appreciate it. I'm certainly no t a pro (hence this post), but I'm approaching novice territory imo. Can anyone suggest next steps given the info provided? Thanks in advance...
