Hello, I have a Sansui AU-222 that I just finished a recap on, first time trying to restore an amplifier and so far so good. The recap seems to have solved my issues with the amplifier popping and hissing after a few minutes of use, however I still have issues with the sound.
I can get the amplifier to sound somewhat okay if I dial it in just right but it seems to be rather finicky in regards to input volume, it seems I have to have the input just right, if it is too low the sound is way off, if it is too high it starts to sound too bassy and pops.
My main problem is that in order to get it to a listenable quality I have to turn the bass knob to 0 and the treble knob all the way up i.e. it is just way to bassy and not enough treble. I was hoping that this would be fixed with the recap but that does not seem to be the case. I realize that I probably need to do a bias adjustment, however I do not have the tools for that kind of job, but if I'm lucky I might be able to get someone to help me with that or borrow some tools. I would like to note that one of the main transistors seems to run much hotter that the rest, could this be related to the bias being off?
Overall the amplifier is in a very good state, has minimal wear and tear and is very clean inside.
So I come here for your help in restoring this beautiful amp. Does anyone here have an idea of what might be wrong with it? Will a bias adjustment solve all my problems or do I need to replace some other parts?
Thanks in advance.
Thanks in advance.
. I'm going to have to see about getting some of that deoxit though, was having my doubts about the servisol anyways.
