jjsxr9
Hi all,
I need to talk this out with someone. Moved into a new house and finally get to open up the system and I'm having issues. I've mostly used the SL-230 in our old house, but since I moved, I have them both going. My old listening room was significantly smaller, so I never really noticed how much the SL-230 was lacking low end.
System:
T1: Beocenter 7000
T2: Technics SL-230
Marantz 2270 (recapped)
Early model Kef 104/2 (new surrounds and ferrofluid) - no Kef Cube, mine quit
its on the list to fix
Symptoms:
The beocenter is very bass heavy but still sounds full, not really lacking highs.
The Technics is very bright with little bass.
Issues I need to fix:
(Beocenter volume slider) When running phono out of the Beocenter, the volume slider introduces a ton of distortion when moved. Bringing it over 50% cuts to one channel. Line out does not work.
(Beocenter tone arm/lifter) I can't seem to find a good balance for the tone arm and I think the lifter needs some TLC. It will drag off a record sometimes
New cartridges for both?
I don't know what my end goal is here... I don't want them to sound the same as each other, but I feel there is a good middle ground I can find.
Any suggestions on how what path to take to get there would be helpful. Im pretty proficient with repair, recapped the Marantz and fixed up the Kefs. Taking apart and cleaning the Beocenter would help I'm sure. That is probably my first step.
Thanks!
System:
T1: Beocenter 7000
T2: Technics SL-230
Symptoms:
Thanks!
