Bajanbmw
Hello AKers
I have read almost all the wonderful postings on the Marantz 1060 but would still appreciate some specific input. I bought a 1060 unit many years ago and used it as a preamp only since the power amp section was completely dead on both channels. The preamp section is still very strong and sounds wonderful but I now want to use it as a stand alone integrated so I recapped the board, also upgraded the three big caps with Nichicon caps and installed 4 new MJ21194 transistors all from digikey. Its not completely dead now but I can barely hear that it's coming to life...(extremely weak attempt at sound output) and if I turn volume up slightly it dies. Since both channels are affected I checked voltage at J709 and its about 72 volts. DBT lights up slightly at start up and then goes out. What's my next step short of rebuilding the entire board?
Thanks in advance!
Thanks in advance!
