BoilermakerF
I picked up a set of Marantz HD-55 speakers this weekend at a yard sale. I figured the L-Pads were probably shot and that's why they didn't work. The cabinets are pretty well shot, but I hooked them up and one speaker's tweeter didn't work and the other's midrange didn't work. That is, until I pressed in on the L-Pad. The tweeter is on a 5ohm pad and the midrange is on a 10ohm. The L-pads appear to be made well enough that they can be easily disassembled, cleaned, and reassembled. I'm willing to try that first to see if I can get them playing again. What should I use to clean them with? 90% Iso alcohol? If it doesn't work, is my best option to replace them with higher wattage resistors or replace them with 8ohm and 16ohm L-Pads realizing that has an impact on the XO frequency due to the changed load?
Thanks,
BMF
Thanks,
BMF
