Need help with PF-800
Paul79
Just upgraded to a pf-800. Worked fine for first day, then the platter wouldn’t stop spinning when I pressed the switch. I had to unplug then plug back in. That worked a few times, now it doesn’t do anything. I took it apart and used Deoxit on all switches and contacts and still nothing. Any help would be greatly appreciated.
Great table. I have one that is working perfectly so have little experience with service. Grab the service manual from Vinyl Engine. Free to join and you must be a member to gain access to the library of goodies. Welcome to AK.
Check both control circuit boards for broken solder joints with a strong light source and a magnifying glass. Would also be a good idea to recap the board.
