need help with SANSUI AU-X911DG
mitro54
Hi. I have this sansui au-x911dg, its my uncles, first off all the cd player doesnt play any burned cds i have played but one few times, them i added music and it stopped working.
So the problem is; i bought rca to play from my phone or computer, since cd player (dvd player) doesnt play my cds. It doesnt detect them or smth..
What is the setups for this amplifier to get it work with rca or is there any way?
Im also curious if the logitech Bluetooth adapter would work but this is my main question. So what is the input setup to get it work with rca-3,5mm jack cable? I think i have tried everything but nope.
If u know solution please tell me. And tell me everything step by step. Im really noob with this.
Doesnt work..
If you are connecting any line-level source (PC, CD player, phone etc) via an appropriate cable which has 2 x RCA jacks, you should DEFINITELY be able to get sound out of the 911DG via the CD, LINE or TUNER inputs. Unless the amp is broken, it's a case of user error. On that note, hopefully the input selection mechanism isn't broken - it is a known issue with these amps.
If you're getting no sound, you may well have one of the various play/record settings for the tape loop set incorrectly. Can you take a very clear photo of the front panel of the amp which shows the position of each switch/button (or perhaps multiple photos)?
The user manual for this amp can also be downloaded here (page 13 is of particular interest):
http://www.hifiengine.com/manual_library/sansui/au-x911dg.shtml
And also, shouldnt it make some noice when its on. I think i remember when it played the music from dvd player, it made some noice like computer, now nothing. I might be wrong. And when i move the volume adjuster, the speaker does some random kzhh noice idk, done it always
No, the amplifier should not make any internal noises during normal operation. The only component on this amp that should make noise is the electronic switching mechanism (DAMS). If you don't hear any whirring noise from the rear right-hand corner of the amp when switching between different inputs, this could be faulty.
To the dvd player. Tried earlier and nothing. Also tried rca to there but nope.
This is not the intended way to connect source components.
The instructions on page 13 of the user manual that I linked to above shows exactly what needs to be done to play a signal via the analogue inputs.
If it doesn't work when following this process, you either have very dirty controls (as evidenced perhaps by the noisy volume pot?) or a faulty DAMS module.
Agree with Pete, the input switching mechanism sometimes get faulty due to the belt. Is it possible for you to change to other input or the button stuck at "CD"?? There should be no connection made to the "processor send/return" unless using equalizer.Weird Pete,my amplifier does not have the speaker impedance selector.
Everything works, the protect delay noice comes, and whirring noice when i i change between those. Just cant get sound
You have the known problem with the dams. The input selector in other words. If your skill is not up to it take it to a tech .
