Need info and recommendations on an OBD II reader or scanner
mech986
AK Subscriber
Hi all,
Did some searches on previous OBD threads but am now seeking your recommendations on good OBD II scanners. I have 2 1997 and 1 1999 Lexus ES300's, a 2004 Toyota Sienna, and a 2000 Porsche Boxster. Various lights are on in the Lexus and Toyota vehicles.
My son's FIL is a mechanic and will gladly read our vehicles for us at his home but its a hassle to get down to him plus imposing on his time.
I've heard you guys recommending to get one, but wondered which units you'd recommend and why? Readers or scanners? Not particularly interested in the Harbor Freight one recommended though.
ODB II is ODB II ... doesn't matter the make or model. The codes and interface were standardized back in 1988 ...
I've got an Actron PocketScan that's been plugging away for years with nary a problem.
The codes are getting a bit dated, but then ... so am I and my cars. <G>
If you do run into a code that doesn't show in the included CD database ... new feature or something specific to a certain model (like the automatic self flushing spitoon in your Lexus), they've also got an online lookup that's updated regularly ...
http://actron.com/code_lookup.php
Hello. For years I used Auterra, on a Palm, and had everything that I needed including much real time info.,if you are in needed of under load figures. Updates are free and they offer systems for Windows, Palm, and others. All of my needs were for German cars, mostly M.B. and BMW, and the information screens are very good. http://www.auterraweb.com/. Good luck.
I have an Actron CP9180 - works great - live sensor data (very cool) you can see this while someone is driving, 02 monitor test,erases codes, looks up code info, memory, emissions status, etc. Check them out on the bay.
Hi - not sure if it's the best but very convienient bluetooth OBDII interface working with android devices. It presents parameters like: injection times, load sensors, pressure etc.. It's called ELM327 w/ BT interface.
HTML:
http://www.youtube.com/watch?v=U-h_J7RDXdw
If all you want to do is read and clear codes there is the neat little Autel MS300 on Amazon for $20. Yes, it's pretty basic but does the job. Enter the vehicle and code into a Google search if the scanner doesn't give you enough info.
I have (had) a scanner for iPhone, but it quit working recently. I'd like to get a new one, and maybe the issues with constant software updates and Apple OS constantly changing, a freestanding scanner is a good idea. No opinions/no research yet, but I'll follow this thread too, and will post when I get a new one.
Charles
Bart, I just bought an Innova 3130. You can borrow it if you want to try it out. It's not the latest "c" model but it should work fine on the cars you listed. Got it for less than $30 on ebay.
- Pete
Bang! Re-upping this thread for more or current recommendations. Hadn't picked up a scanner but still looking for one.
HTML:
I just got one of these as well......http://www.amazon.com/gp/product/B005NLQAHS/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
I paired it with the "torque" app and I think it's super cool....
I was able to chase down a problem on my suburban (misfire no. 3 cylinder) by erasing the code, fixing one thing.... Then watching the "misfire counter" with it running to see if my fix actually CURED the problem...
Turned out to be a bad distributor cap but I didn't need to throw a bunch of un-needed parts at it and "cross my fingers"
Just a "FYI" I bought the paid version of torque after I first run the freebie version to make surf everything would work with my setup
I considered this one...but for really not a lot more money i got the autel al319 instead...it's a bit more capable with a color screen and live data etc,it's also updateable via USB with it's included software[and mine needed to be,but the update process was painless and totally fixed my issue].
it's for sure not the best out there and is limited compared to higher end ones,like most cheaper scanners it doesn't go beyond the OBD2 fuel injection systems,no ABS or other body computer functions.for my basic uses the al319 has been a great little gizmo but if i see a deal,my next one will include those extended functions...they tend to cost a LOT more but it makes them far more useful in modern cars
I have a fancy one from Pep Boys and a basic reader that I keep in the glove box. I could live with just the basic reader.
