Need multimeter recommendation.
The Tenma AC frequency response is only 40 Hz - 400Hz.
However, the Fluke 115 at $150, only goes out to 1KHz. On a new meter you are going to have to spend a lot more than that to get flat frequency response out to 20KHz. If you need to do that you are better off with a used benchtop meter like my Keithley 197. Accurate measurement of frequency response is a whole different level of test equipment. The OP is looking for a meter for general troubleshooting. For that, If you compare the specs of the Tenma above with the Fluke 115, I think you will see it stands up very well for 1/3 the price. Nothing against Fluke, I just want to say you don't have to spend $150 to get an excellent hand held DMM.
If you need acurate RMS measurement up to 100kHz, Amprobe AM-160 is probably the cheapest option.
I agree entirely, if you want a good DMM with everything you need, these are not el-cheapo units, they are well made and perform perfectly.
IMO the only thing you will miss out on is the Fluke warranty and the Fluke name, if Fluke is the Rolls Royce these are a Mercedes. :thmbsp:
I conducted a similar search. I ended up with a TENMA auto ranging meter for about $50. It has been easy to use, reliable, and cost effective. For me it was the perfect choice. Newark has them on sale periodically.
Good luck.
You probably don't need to go out and buy a Fluke right away, but consider that if you spend 30 bucks now on a cheap meter and break it it in a few months, what will your next option be? The $60 meter? Now you have spent close to $90 which could have gotten you a decent new Extech or used Fluke. You may have spent more money up front, but a meter like this would hold its resale value later on in case you decide electronics isn't for you and want to sell it. Just something to consider...
I have access to NIST-calibrated Fluke's, so those are the only meter I'll ever use. But if I had to buy one on my own I would probably get an Extech. They seem very rugged and a good value at the price for the features.
