need repair advice denon DRA 685
RoyAbles
I recently picked up a Denon DRA 685 at the local thrift store. The problem is the left channel is dead with a hum, it's not the typical AC hum but its there none the less. The right side has sound but it's nowhere near loud enough and has the same buzz at a lower volume.
IS the unit's sound quality worth the effort to repair or take my losses and move on.
I'd like to repair myself but I've hit a wall, nothing obvious. visually everything seems in order no pregnant cap's, signs of overheating. no signal in the collector of the output tran's so i figure pre amp or input board.
ANY help would be appreciated
Welcome to AK...Sounds like a power supply issue. Bad electrolytic capacitor...
Wouldn't happen to have a service manual,would you? Probably the closest I can get is a DRA-585. Its power supply has a good chance to be similar.
I wish.....got it at a thrift store rolling the dice it worked, but you are probably right. So you suspect the power supply then..... I didn't think to look there
Oh and i forgot to say that the base leg off the output transistors is 50v positive and negative across all 4 transistors
Lets hope not..The collectors should have +/- 50vdc. Center pin is the collector if it is a TO-3P output.
well now its making sense it is indeed the center leg is 50vdc....havent used my electronics training in 30 years and i ass-u-med it was right to left collector,base ,emitter
FWIW, I fixed a Denon beast AVR from about that vintage that presented a hum. It was a bad bridge rectifier. If your main caps voltage is all wonky, look to the bridge.
how do i know what the voltage is supposed to be on the bridge.....the bridge is loacted next to the red, orange ,yellow wire connector
Two pins will have AC voltage and two pins will have +/- DC voltage.<--- likely +/- 50 vdc if the bridge is for the unregulated DC supply for the output transistors.And roughly 38 VAC from the power transformers secondary.( red, orange ,yellow wire connector)
Okay, from the notch on the bridge reading left to right pin1 is 118vac, pin2 is 41vac, pin3 is 41vac, pin 4 is -51dc
orange and red wire from the master transformer has 41vac, yellow =0IMG_1088.JPG
If your getting stable +/- 50 vdc to the outputs. There is nothing amiss with the bridged rectifier..
No way you have 118VAC on that rectifier. Your measuring incorrectly.
Imprinted in the plastic right above the pins on that rectifier are symbols ( + sine sine - ) not necessarily in that order. I can't make them out in your photo.
index.php
