svelto916
I need some help with my Sansui 7070. I am not very techy as my explanation of the problem will demonstrate.
My Sansui 7070 had been working great, nice CD player connected + Airport Express/airplay and B&W 601's..life was good.
I recently went to use the 7070 and my left speaker was toast. *&(*(^!!@!! At first I thought the wires came loose with dusting, so I moved my right speaker over (to the left) and it worked fine, moved my left speaker over to the right and there is almost nothing coming out. I always turn the volume all the way down when I turn the unit off, so when i refer to turning the unit on..the volume is always at the lowest setting.
I notice that when I turn on the 7070, after about 2 seconds I hear a click and the left VU meter jumps about 1/2 way then goes back to zero and I can get nice sound out of the 7070. That is the current situation...however, a time or two the left channel VU meter pinned itself to the right (full) for a second or so on startup before I turned it off.
This is all I have done so far to try and trace the problem:
I replaced the 3 fuses. Nothing inside the unit seems odd, overly hot/warm or burned with the exception on board F-2626, R13 and R14 at the top (small white rectangle boxes) get almost too hot to touch. Everything else is fine, lights, fuses, treble, mid-range, bass control, AM/FM, filters etc.
If I remove board f-2626 and turn it on, I get pop from the left speaker and a slight hum. If I remove both f2626 & F2624, and start the 7070 I get a nice, normal sounding click after two seconds with no pops or movement from the VU meters.
Does anybody know, based on this description, what is going on and how to fix it? Any help would be greatly appreciated. Even if it is a repair shop recommendation (near the northern part of IL)..because last time I had a problem with it (two years ago) the repairman in my area said it was not worth fixing...I was very thankful I found this forum. I will also add that we've had some bad storms, and this could be power surge related...but have not had problems with any other electronics in the home.
Thanks
-Chris
Thanks
-Chris
