Need service manual for Luxman KX-101
xchg.ca
Got this 1983 beauty just over the weekend
Looks like need some cleaning and Servo Face is not operational - which I do not think it is going to be a problem to fix.
But for general tuneup and calibration I need service manual
Cannot find one
May be someone somewhere has a scan of the Service Manual ?!!
Thank you
I have the same deck-I needed another cassette deck like I needed a hole in my head.......but I thought it was a looker, and the suck face, a cool gimmick. It sounds very good in any event.
The main belt and the servo belt were bad. The main belt is flat out the easiest to replace of any deck I have encountered. I think it's one or at most two screws to remove and replace-and there's plenty of room to do this without more than removing the bonnet. Transport stays put. Easy peasy. If you have modest mechanical skill-it will be pretty obvious which screw(s), need to be removed.
I recall it being one screw, and just sliding the motor assembly out of a locating pin, cleaning of surfaces on the flywheel and pulley, slipping on the belt around the flywheel, then keeping a bit of tension on the belt as you hook the pulley onto it, and then re engage the locating pin, then replace the screw.
Now, the suck face belt-that's another story. I examined the mechanism, and concluded, it was not worth the hassle. The motor and associated geared mechanism, which has the tiny belt inside, is "held prisoner" in the guide rail system, as far as I can tell. I wound up disconnecting the associated motor wiring harness plug, then retracting the mechanism to reveal the knobs, and zip tied it in place. That is how I have used it for about 3 years.
I never found a service manual either.....
I have the following note by an AK member,( I think) I have no idea of who posted it:
"It's really silly easy to replace the belt and get it to work. If you haven't ordered the belt yet, get yourself a 21mm I.D. 0.8mm thick square rubber belt (I got mine from eBay seller "dalbanicorporation"). That's probably all you need."
Like many posts, it was clearly short on details-kind of a statement, suggesting that no further explanation is needed, unless you are a total noob-lol
If you discover a replacement method on the suck face mech, please share it with us-I would love to learn how. Thanks!
Here's one for a few bucks.
Thank you @dankik
For some reason 5$ for shipping to Canada turns into $15.... + TAX and all together it is 2 times more expensive that I paid for the deck itself :D
But may be it worth buying and then scanning to have it available for the community !
Hi, I recently bought a KX-101 SM from a hi-fi repair shop in Colorado Springs for $8 plus $2 to ship, so if you are still in need of one I will post it. My experiences from getting mine to work properly, replace all the orange film caps. Several AK'ers and I found some of these to be very noisy.
Oh wow! This is really good price ! I got one for 20 :D
Please post service manual, this would be appreciated by so many people ! :banana:
Thank you !!!
Doh! I just realize - you were talking about Service Manual but I thought you purchased the whole deck for 8 :D
Sorry for confusion
Suck face repaired !
Can you share how you did this? It's looked like a near teardown of the drive chassis to do it, so I let it slide. It would be great if you found an simpler method without so much disassembly.
Hi, I've replaced the suckface belt on a KX-100, KX-101 an RX-102. The earlier post with the Youtube video is how its done. Have not found any easier method. The tape decks are easier than the receivers because the RX suckface drive mechanism is flipped 180 degrees so you remove it from the bottom of the receiver.
Here is my take on Suck Face repair:
Ans there is no easy way to fix it, unfortunately. Explanation is in the video, as well as cursing and swearing :D
Although I play for pride routinely, I think I will just let it be. I zip tied the carriage back and pulled the motor connector. Good enough for now.
It is an option and, as you might notice in the video, it sounds a bit annoying - every time you turn it on and event worst when you turn it off !
And here is the final video in glorious 4K demonstrating this beautiful vintage masterpiece in all its glory:
