EJC1
I got involved restoring a Thorens TD-160 and hit a snag.
This is US 110v 60hz TT
The TT was damaged by UPS and had a broken motor shaft.
So I look for a motor and all I can find are 50HZ motors.
That's fine I bought a motor, installed it and it was working properly at 40.1RPM
I needed a 60HZ pulley. The one that was on the TT was the type that used c-clip retainers and not the brass type with the side screws. So I can't use the original pulley.
I ordered the Audio Silente 60hz pulley, I was able to remove the c-clips to get the spring from the original pulley.
The pulley works and the speed is at 33.4-5.
But I have no retaining ring on the top of the pulley.
Anyone have any ideas how best I can resolve the situation (without buying another motor)?
